Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through February 23, 2006 > Denon AVR 3805 and Infocus Projector ...
Author Thread: Denon AVR 3805 and Infocus Projector SP4805
Messed with the 3805's setup menu and now there is no picture, only sound. Projector has component going to monitor on receiver.
What should my settings be on the Denon?
When I use the s-video from projector directly to cable box, we get a picture.
Username: Chitown
Post Number: 763
You sure it's not the setup on the 4805? Are you using the component to s-video converter that comes with the projector?
Are you able to connect the component to a TV and see if you get picture?
I'm pretty sure it's not the 4805. I did not even touch that when I was fixing the radio tuner.
When I get home from work tonight I will try connecting the component to a tv. Thanks.
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through February 23, 2006 > Denon AVR 3805 and Infocus Projector ... [ « Previous ] [ Next » ]
