Thread: Confused about what speakers to use for karaoke |
New member Username: Pcdoctor
Post Number: 3 Registered: Aug-05
| Posted on Sunday, February 12, 2006 - 03:04 am: |
I have the following Mirage speakers: Left and right fronts - OM10 Center - MCsi Left and right rear surrounds - 595is (I'm using a Yamaha HTR5250 receiver) I sent Mirage's tech support and told them that I wanted to use my home theater for karaoke. This is their response. "Hello, Sure, you can use your speakers for Karaoke. However, please be cautious not to overdrive your receiver as clipping sounds could damage the speakers... Enjoy" Anyone else using their Mirage or home theater speakers for karaoke? If so, have you damaged any speakers? If anyone recommends that I purchase dedicated karaoke speakers for my home theater, what do you recommend? I thought about getting some Vocopro SV-300s and connecting them to my Yamaha speakers B terminal. Also, if home theater speakers are horrible for karaoke then what do companies use in their all on one karaoke units? Ex. Vocopro Duet II http://vocopro.com/p_sysh.html#duet2 Vocopro's website says the duet II uses stereo speakers. Are the stereo speakers used in all in one karaoke systems hifi speakers or karaoke speakers? Thx for any input. |
Post Number: 5607 Registered: Dec-03
| Posted on Sunday, February 12, 2006 - 03:24 am: |
That is a disclaimer for a lot of home speakers. You really have to be careful with using karaoke with regular home speakers as the microphone and the human voice can really drive up the output to clipping levels. You can use them, just be careful to modulate the volume so you do not overdrive the receiver to clipping levels. Specially if the user has a powerful voice. Clipping is never good for any home audio equipment. You may want to look at professional speakers for karaoke. |
Post Number: 9 Registered: Aug-05
| Posted on Sunday, February 12, 2006 - 10:14 am: |
Yes, I think I'm going to do that. I'm on a budget. Do you think the Vocopro SV-300s are any good? http://vocopro.com/p_kvs.html#sv-300
Post Number: 5627 Registered: Dec-03
| Posted on Sunday, February 12, 2006 - 05:25 pm: |
Oh yeah, the Vocopro's are very nice. I guess that gives me away, huh? I swear my kids are crazy about karaoke! |
