Thread: Additions. |
New member Username: Revenga444
Post Number: 1 Registered: Feb-06
| Posted on Saturday, February 11, 2006 - 03:54 pm: |
I own this:http://www.brookstone.com/shop/product.asp?product_code=512574&search_type=searc h&search_words=micro&prodtemp=t2&cm_re=Result*R1C1*A Would I be able to add something like this to it? http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=10682 38&CatId=98 If not, is there anything I can add? Thanks. |
Post Number: 5563 Registered: Dec-03
| Posted on Saturday, February 11, 2006 - 07:34 pm: |
I don't think that player has any outputs, so you will be hard pressed to expand it. Find out its capabilities. If it does not have any outputs, then no, there is nothing you can add. |
Post Number: 2 Registered: Feb-06
| Posted on Sunday, February 12, 2006 - 12:53 am: |
It has a left and right line out. So I assume this means I can add two speakers? |
Post Number: 5608 Registered: Dec-03
| Posted on Sunday, February 12, 2006 - 03:25 am: |
If it has a left and right output, then yes you can hook it up to a set of powered speaker like the ones you are planning on using. |
