Home > Message Board > Home Theater > Home Theater Speaker Packages > Archive through June 05, 2006 > Bose Acoustimass 16.. Need recommenda...
Author Thread: Bose Acoustimass 16.. Need recommendations for a Receiver
Username: Stanz12
Wife recently purchased an Acoustimass 16 for me. Curious to know what would be the recommended or suggested receiver?
I currently have an Onkyo HTR520 which supports the 6.1 Bose system, however I'm curious to know if there is something out there that will support it better.
Username: Project6
Post Number: 5512
Nothing out there will support Bose any better than what you currently have. If your goal is to get a better sounding system, replacing your current receiver is not the right place to start.
Try listening to other speakers and you will know what I mean.
Username: Dfantom32
Irvine, CA
Yes its true Soundwave what berny said about the receiver for your AM16, unless you want to get a better sound you need to check the speakers first then from there you know where to start. :-)
Username: Gavincumm
New York
Post Number: 548
if you like the small size of the Bose speakers, Orb Audio, which are a hair larger than the Bose, will wipe the floor with them in overall sound quality. Not to mention they are cheaper.
Orb speakers come in the standard black and white, but also have the option to come in a downright BEAUTIFUL hand polished copper finish, as well as steel.
I hope you can return the bose for the sake of your ears.
www.orbaudio.com
Username: Mccambley
BREEZY POINT, NY
Post Number: 71
I am not a Bose fan, but since you already have them one upgrade would be to replace the sub.With the Bose system you run the speaker wire from the receiver to sub and then out to the speakers. Using a real powered sub that connects to the reciever with an RCA jack and plugs into the wall.Then the speakers can plug directly into the reciever.The Bose sub is not powered and is taking all the watts the reciever is pushing out befor sending the little that is left out to the speakers.
Username: N8d1
Baltimore
Post Number: 16
I would take caution in not using the Accoustimas module. The satelites need the crossover that is built into it. Even if you cross them over from the receiver, you may be sending frequencies that are too low for them to handle. I'm not possitive but the power to them may be controlled by it as well. You have a good chance of destroying them if you connect them directly to your receiver. ...which may not be a bad thing. You could always add a true subwoofer and use the LFE/Subwoofer out from your receiver to run it.
Home > Message Board > Home Theater > Home Theater Speaker Packages > Archive through June 05, 2006 > Bose Acoustimass 16.. Need recommenda... [ « Previous ] [ Next » ]
