Thread: New wiring and sound shuts off after a few minutes (help) |
New member Username: Tom55555
Post Number: 1 Registered: Feb-06
| Posted on Thursday, February 09, 2006 - 02:01 am: |
Hi. I just upgraded the wiring for my Panasonic home theater system with Monster THX 16awg speaker wires. Within a few minutes of playing my XBox (optical connection), the sound unexpectedly shut off... no warnings, crackling, error codes, etc. If i turn the receiver off and back on again, everything is fine but then sound cuts off after a few more min. I've triple checked all connections (+/-, signal direction, wires touching, etc.) and haven't found anything wrong. Any suggestions would be appreciated. Thanks in advance. |
Post Number: 5450 Registered: Dec-03
| Posted on Thursday, February 09, 2006 - 02:04 am: |
Signal direction??? Explain this signal direction! Does the sound just cut off or does the receiver go into protect mode?
Post Number: 2 Registered: Feb-06
| Posted on Thursday, February 09, 2006 - 07:28 pm: |
Thought maybe this will help others out... I've noticed others below have the same problem as I had. When installing wires, I used Monster connectors (braided type) on the wire tips.. seems that was the problem. I removed the connectors and just connected the bare wires, everything is fine now. |
