Thread: Is the room big enough? |
New member Username: Peteinpa
Post Number: 1 Registered: Feb-06
| Posted on Monday, February 06, 2006 - 06:31 pm: |
Hi all, i have a room in my basement that is (16 x 13), is that large enough for a home theater using a rear projector and assuming i want two rows of seating? I just keep looking at it and cannot determine if it will be enough room, especially for those who sit in the front row. |
Silver Member Username: Chitown
Post Number: 737 Registered: Apr-05
| Posted on Monday, February 06, 2006 - 10:31 pm: |
Why not go for a front projector installed into the ceiling? Takes up much less room and in most cases can probably deliver a better resolution.
Bronze Member Username: Hogwild
Post Number: 29 Registered: Aug-05
| Posted on Tuesday, February 21, 2006 - 09:34 am: |
If you can place your screen on the 13 ft wall you should be able to accomodate both rows of seating (not closer than 10 ft) and a 92 inch screen easily. (Closer than 10-12 ft and your screen should be smaller.) You should also have a couple of feet behind your second seats for a rear speaker or two.
Bronze Member Username: Em69
Ottawa Canada
Post Number: 67 Registered: Mar-05
| Posted on Wednesday, February 22, 2006 - 09:55 am: |
When I draw out the plan, I am getting the front rows to be about 8 feet from the screen when placed on the 13 foot wall. It seems pretty close. Depth of each row of seating: 36"x2=72" Leg room between first and second row: 24" This leaves about 8 feet to the screen. The distance to the first row should be 2-2.5 times the size of your screen. |
