Home > Message Board > Home Theater > Home Theater in a Box > Archive through April 22, 2006 > HT-S780 Modified Brillance
Author Thread: HT-S780 Modified Brillance
Username: Viiofix
New Haven, Ct.
New Haven
Post Number: 17
I bought the Onkyo HT-S780 like many of you. For me, it was after spending so much cash on the Toshiba 72MX195 and to have such a set without the Surround Sound just didn't seem right. Problem is, the Surround L/R and Back L/R Speaker are crap.
I had four Bookshelf JBLs in my Studio so I borrowed them and replaced them with the afore mentioned. There lays the difference between sounds good to sounds awesome.
I realize it's kinda dumb to spend cash on these speakers and not use them but if you have JBLs or any other higher quality speakers that you can exchange for the Backs and sides, you will hear a whole new experience with this system.
Username: Project6
Post Number: 5252
That is why it is highly suggested to avoid HT in a box if you have the budget.
Home > Message Board > Home Theater > Home Theater in a Box > Archive through April 22, 2006 > HT-S780 Modified Brillance [ « Previous ] [ Next » ]
