Thread: How Can I Use My Speaker...? |
| Posted on Wednesday, February 01, 2006 - 10:26 pm: |
Hey all, I got a Sony DAV-DX150 5.1 DVD (SRS in a box), it only has RCA analog inputs. no audio outputs what-so-ever. The speaker connection to the DVD player isnt standard wires, its color coded plugs. my dad said that we needed a receiver so we bought one (Pioneer VSX-515K). we kinda do need the receiver but we dont want another set of speakers. is there like a splitter for speakers? like can i use one set of SRS speakers with my DVD player and receiver. connect both of the devices to a speaker as in putting 2 speaker cables into one input on a speaker??? |
Post Number: 5104 Registered: Dec-03
| Posted on Wednesday, February 01, 2006 - 11:26 pm: |
Isn't that unit a stand alone Home Theater in a box? http://www.vanns.com/shop/servlet/item/features/501223117 You really don't need anything else with that. Everything should already be there, including the receiver. |
Post Number: 5105 Registered: Dec-03
| Posted on Wednesday, February 01, 2006 - 11:27 pm: |
Where are the instructions? Have you read it? It will really help you out if you read the manual first. |
| Posted on Wednesday, February 01, 2006 - 11:54 pm: |
yeah i have the DVD w/ 5.1 already setup... i kept telling my dad that we didnt need a receiver but he insisted on buying it. anyway its way too late to return it, i might as well find a way to use it. that is why i want to find out if there are speaker splitters, or if its ok to put 2 speaker cables into the speakers. http://webpages.charter.net/p1n0y/Setup/untitled.JPG |
Post Number: 5117 Registered: Dec-03
| Posted on Thursday, February 02, 2006 - 12:52 am: |
I wouldn't do that. Leave the home Theater alone and do not attach anymore speakers that is not designed to attach to the unit. Unless you insist on seeing the protect mode, from which you can't go back. |
Post Number: 5118 Registered: Dec-03
| Posted on Thursday, February 02, 2006 - 12:54 am: |
If you have a separate receiver, use a different set of speakers, not the one that is already being used by another unit. |
| Posted on Thursday, February 02, 2006 - 06:22 pm: |
ok just making sure. i have already short circuited the DVD player before...just got it fixed a few weeks ago. |
Post Number: 5140 Registered: Dec-03
| Posted on Thursday, February 02, 2006 - 06:25 pm: |
Seems like a good time to buy a new set of speakers for the other receiver. |
| Posted on Thursday, February 02, 2006 - 07:04 pm: |
yeah im looking for some so that we can put it in the garage for karaoke or the family room. |
Post Number: 5145 Registered: Dec-03
| Posted on Thursday, February 02, 2006 - 07:48 pm: |
Sounds like the perfect excuse for your dad to have another system for karaoke. You have a budget for a new set of speakers? |
| Posted on Thursday, February 02, 2006 - 09:21 pm: |
umm...right now im not sure how much my dad is willing to spend.. but IMO i think he's willing to spend no more than $150...i know its kinda cheap but it needs to be simple.. and plus my parents need a new TV for their bedroom, so im not sure how much he's gonna spend or when he's gonna buy it.. i was looking at the MTX HTB1 S 5.1 SRS system at circuit city for like <$200. do you think that's anygood? |
| Posted on Thursday, February 02, 2006 - 09:23 pm: |
http://www.circuitcity.com/ssm/MTX-Home-Theater-Speaker-System-HTB1S-/sem/rpsm/o id/140262/catOid/-12950/rpem/ccd/productDetail.do |
