Home > Message Board > Home Theater > Home Theater Speaker Packages > Archive through December 09, 2006 > Which speakers to buy
Author Thread: Which speakers to buy
which speakers should i buy for watching movies more than music jamo e855 or e650 or dali new 1.7 suite will be running an pioneer amp vsx-ax2av-s and a pioneer dvd player dv-989avi-s
Username: Project6
Post Number: 5094
Have you heard any of these speakers?
yes i have the dali sound a little bit better in the bass.
Username: Project6
Post Number: 5132
I think that your choice is clear. If you are leaning towards the Dali, I say go for it, you'll be happier.
shortcut
So is better bass a priority to you? If it is, go for it. What are the mids and highs like? Most people tend to prefer a well rounded speaker that doesn't have an empty spot in the mids or overbearing, highs.
Username: Phi_do410
Ho Chi Minh, Saigon
Vietnam
Post Number: 11
I have the same receiver (Pioneer VSX-AX2AV-G, the rated power is 250Wx7, 6 Ohm) and I'm looking for speakers which I can play music 50% and movies 50%. Anyone can help recommend me a complete system. I'm considering the energy C-3, C-C3 but not decided yet as the power rate of the C-3 is only 125W and am not sure if it is an issue.
Username: Project6
Post Number: 11126
It is not an issue.
Username: Phi_do410
Ho Chi Minh, Saigon
Vietnam
Post Number: 12
Berny, thanks for your prompt response. I also wanna buy a surround sys and subwoofer and center, what do you recomend then, to match with the C-3 bookselves speakers (if you thinks that my selection is ok). Appreciate your advice.
Username: Project6
Post Number: 11128
Why not stick with the Energy line? for your subs, check out HSU, SVS or Velodyne.
Username: Phi_do410
Ho Chi Minh, Saigon
Vietnam
Post Number: 13
Thanks for the recommendation. Somebody has told me that a Canadian speaker branded PSP is best matched with the vsx-ax2 Pioneer receiver... Do you know of this brand and if yes, how is it compared to the Energy ones? Thanks.
Username: Project6
Post Number: 11152
I haven't heard of a brand called PSP. I've heard of PSB, good speakers but you have to listen to make a determination, because nobody knows what you will like.
Home > Message Board > Home Theater > Home Theater Speaker Packages > Archive through December 09, 2006 > Which speakers to buy [ « Previous ] [ Next » ]
