Home > Message Board > Home Theater > Home Theater in a Box > Archive through April 22, 2006 > Pansonic
Author Thread: Pansonic
Gary Forrest
I have a Panosonic SC HT920 Home theater sound system. I want to put in ceiling rear speakers.The ones that came with system are 4ohm 70 watt rear surround speakers. Does anyone have a suggestion for what to use?
Thanks
Lalldex
I can't say much but make sure they match the same 4 ohm impedance otherwise you may damage your amp/receiver. Have you thought about simply getting some ceiling/wall brackets and using the speakers that came with the system? You can terminate you in-wall speaker cable with a terminal block and simply run a tail out of the surround speaker and if you ever decide to put in-wall speakers in you already have the wiring there. Just make sure its bigger wire just in case you think about upgrading to a bigger amp/speakers in the future. It's not much but I hope I helped.
Home > Message Board > Home Theater > Home Theater in a Box > Archive through April 22, 2006 > Pansonic [ « Previous ] [ Next » ]
