Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through January 29, 2006 > Help Check My Set Up Please
Author Thread: Help Check My Set Up Please
Username: Runner440
Raleigh, NC
United States
My gold is to run all my audio through the receiver and get the best video signal to the display. Is the hookup I listed right?
Pioneer PDP-4360HD Plasma Display
Input--HDMI from 8300HD Cable Box
Input--Component Video from SVP-7700
Scientific Atlanta Explorer 8300HD Digital Video Recorder (Cable Box)
Input--Cable In
Output--HDMI to PDP-4360HD Plasma Display
Output--Digital Out Audio (optical) to STR-DA5ES Receiver
Sony STR-DA5ES AV Receiver
Input--Digital In Audio (optical) from SVP-S7700 DVD
Input--Digital In Audio (optical) from 8300HD Digital Video Recorder
Sony SVP-S7700 DVD Player
Output--Component Video to PDP-4360HD Plasma Display
Username: Mccambley
BREEZY POINT, NY
Post Number: 50
Looks good to me . If you ever do a multi room set up you will need to use anaolog in adition to your digital audio connections, digital will not pass to multi room.
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through January 29, 2006 > Help Check My Set Up Please [ « Previous ] [ Next » ]
