Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through January 29, 2006 > New selfbuild
Author Thread: New selfbuild
Username: Steroachy
hi
i have just started my selfbuild 4 bed bungalow and would like some advice on multiroom audio, i dont have a budget for a hi-end quality system, i would like to build the speakers in to the walls. any advice about which quality components, speakers, amps, hubs-distribution boxes will be most welcome
slumlord
i didnt know you could put all that in a lean to behind walmarts in the bushes
Username: Project6
Post Number: 4905
Budget?
shamuchef
yea possibly if you budget you just might get it in there
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through January 29, 2006 > New selfbuild [ « Previous ] [ Next » ]
