Thread: New 7.1 System |
7.1_ht_noob Unregistered guest |
| Posted on Monday, January 23, 2006 - 05:13 pm: |
I'm excited because I finally got to the point where I can put together my 7.1 system. I bought a 50" Sony SXRD last week and am ready to move to my AV receiver and speaker options. I'm leaning heavily toward the Yamaha RX V-2600 but I am at a loss on what speakers to get. I wired for 7.1 last year and am ready to make that happen!! Any thoughts or help would be appreciated!! Thanks!! |
Windork Unregistered guest |
| Posted on Friday, January 27, 2006 - 07:22 am: |
Good choice, Yamaha is good stuff. As far as speakers go, to fully appreciate a good set of speakers you have to know what bad or mediocre ones sound like right? I suggest you don't buy an expensive set till you really know what you want. By the time you know (months/years later) you should have enough saved for a great set and you'll know you got what you paid for. Just a suggestion, it's what I did and I'm quite happy with my setup. Call it an education. |
Post Number: 4969 Registered: Dec-03
| Posted on Friday, January 27, 2006 - 10:27 am: |
What is your budget for speakers? |
| Posted on Friday, January 27, 2006 - 04:22 pm: |
Roughly $1250...do certain speakers sound better with the Yammie. |
Bronze Member Username: Dobyblue
St. Catharines,
Ontario
Post Number: 25 Registered: Oct-05
| Posted on Saturday, January 28, 2006 - 02:07 pm: |
Paradigm. Best value for money. |
Post Number: 4977 Registered: Dec-03
| Posted on Saturday, January 28, 2006 - 10:18 pm: |
There are those who prefer certain speakers with a given receiver. It is totally up to the end user as to what they prefer. Paradigm seems to be a favorite with Yamaha owners. There is also Ascend Acoustics. You should also consider them as well. http://www.ascendacoustics.com/
New member Username: Rlr267
Post Number: 3 Registered: Dec-05
| Posted on Monday, February 20, 2006 - 03:04 pm: |
How does Klipsch Reference series stack up agains the Pardigim speakers for Yamaha recievers? I am new to this and have a Yamaha RX-v750 but have not decided what speakers to go with yet. I am putting this in the family room (20 X 21 with 10 foot ceilings and hardwood on the walls). I am considering the RF35 floorstanding speakers with RC-35 center channel and some CDT-2800-C (8" round ceiling mount with aimable tweeter and woofer) for both the rear and surround (7th channel) and rounding out with the RW-10 sub. Any opinions? This system will serve double duty, 75% music, 25% surround sound/theater. |
Post Number: 6115 Registered: Dec-03
| Posted on Monday, February 20, 2006 - 06:09 pm: |
The RF-35 are more forward than the Paradigms at least to my ears, but a lot of people like them. I like the RF-35, I think it is very detailed, but a little too "in your face". |
| Posted on Monday, February 20, 2006 - 08:25 pm: |
How do you mean? Too much high or too much bass? I'm interested in these speakers as well. |
Post Number: 6167 Registered: Dec-03
| Posted on Tuesday, February 21, 2006 - 01:56 am: |
A tad on the high side. |
