Home > Message Board > Home Theater > Home Theater in a Box > Archive through April 22, 2006 > Rear and center speaker activity prob...
Author Thread: Rear and center speaker activity problems (during cd play)
Evan424323
A little help please, i have an electrohome theatre surround sound in a box, i cant activate the center or rear speakers during cd play, (the device has its own dvd player for it). I know its not a connectivity issue becuase everything works fine durint movies, ive fiddled with the menus and what not and cant seem to find anything to activate it, anyone else with the same problem? and any means of fixing it?
Username: Project6
Post Number: 4840
What other surround modes do you have on that HT?
The problem is the CD itself. If the material is recorded in stereo only and not multi channel, the center and surrounds will not work. If your HT has other surround modes you should try using those.
Home > Message Board > Home Theater > Home Theater in a Box > Archive through April 22, 2006 > Rear and center speaker activity prob... [ « Previous ] [ Next » ]
