Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through January 29, 2006 > Multiple sources on a single co-ax line?
Author Thread: Multiple sources on a single co-ax line?
Username: Captain_america
I have the idea of placing all of my DirecTV boxes in my basement and then simply running a single wire throughout my house to connect all my TV's. The problem is, is that the co-ax output is only on channel 3 or 4, and if you hook up multiple boxes together, only the box nearest the TV (in terms of through the cable) will show...IE I set box a to channel 3, plug its output into the input of box b, then set box b to output to channel 4 then plug it into the tv, I only get a signal on channel 4. The other problem is is that I have 3 receivers so I would need one to go to channel 5 as well.
Is there such thing as a cable TV modulator that can take multiple inputs and then output them to desired channels?
I guess something like this:
http://www.venditions.com/Store/display_item_detail.asp?system=1&prodid=30&categ id=32&subcategid=379&itemid=DBM61151
But without the need for manual input selection...This device takes 3 inputs and outputs them all on channel 3 (or 4), so I would have to run downstairs to select a new receiver to watch...also, I wouldn't be able to watch different receivers on different TVs.
This one looks better, but it is only a two inputer...
http://froogle.google.com/froogle_cluster?q=cable+tv+modulator&pid=4829187676308 366944&oid=1346524360999487798&btnG=Search+Froogle&oi=froogler&lmode=&addr=&scor ing=p&hl=en
Anyone have any experience with these? Do they make a triple input version?
Jay L
I'll bite. Why?
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through January 29, 2006 > Multiple sources on a single co-ax line? [ « Previous ] [ Next » ]
