Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through January 29, 2006 > Set-up Question
Author Thread: Set-up Question
Username: Tataynik
I have a Toshiba 53hm85, Yamaha HTR5840, Sony DVD (w/ HDMI) and a non-HD satellite receiver. The satellite box has S/PDIF and Red/Yel/Wht RCA connections. How can I connect these units so that I can watch satellite using the TV speakers (most of the time) and watch movies using the receiver when for better (dolby) sound. Right now I have the Satellite connected directly to the TV using the RCA connections. I have also tried connecting the satellite box to the receiver, and it works too. What I need is a connection to the receiver that would still allow me to watch using just the TV speakers. Any help would be appreciated.
Username: John_s
Columbus, Ohio
US
Post Number: 615
Tataynik,
Since your Yamaha receiver has only one coax (S/PDIF) input, I would connect the sat box's output to that. That way, you can watch the sat signal and hear any digital (DD 2.0 or DD 5.1) audio into your external audio system. By using the RCA connections into the TV, you can still use the TV's speakers, if you choose.
Your Sony DVD player no doubt has both optical and coax digital audio outputs. You should use an optical (Toslink) cable to one of the two optical inputs on your Yamaha. There may be some setup programming required on the receiver so that it will recognize those two incoming digital audio signals on the inputs of your choice. Consult the Yamaha owners manual on this procedure.
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through January 29, 2006 > Set-up Question [ « Previous ] [ Next » ]
