Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through November 16, 2003 > Hum in Center Channel
Author Thread: Hum in Center Channel
I have hum in the center channel speaker placed on top of the Mitsubishi wide screen. I have Onk 650 rec., Klipsch reflex center channel speaker and Klipsch relex speakers for surrond (ceiling mounted). The hum sounds when the TV is turned on and is noticeable at low volume. When the TV is off the hum disappers. Can anyone help me trace and fix the problem?
Hi Anonymous..>> Nice to meet yea.
Check all your cables...Be sure to keep all your video and audio separte and apart as best you can..might be feed-back...hummmmmmmmm noise, i would think here..If not try another speaker cable, one never knows, as your tring to truble shoot this, i'm sure this will get you out of your trouble as the speakers your using are ok, for this use.
If this dont make the grade here, i would like to have you try new interconnects untill you find your feed-back RFG noise.
I remember one day ..I was getting a weird omg radio nose noise comming from the left back speakers...>> Not every day you pick up a Russion radio station....lol
stay in touch....
Donald L. Suedmeier
ps..there's other things to do..lets start with this ..will get it !!!!
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through November 16, 2003 > Hum in Center Channel [ « Previous ] [ Next » ]
