Home > Message Board > Home Theater > Bragging Area > KrazeyKow's Mad Theater
Author Thread: KrazeyKow's Mad Theater
Username: Krazeykow
Hey, I'm new to the boards and though I would share my mad cow setup.
[b]Equipment[/b]
TV:46" Sammy DLP HDTV 720p(Perfect for Room Size)
Recv.:7.1 Channel A/V Receiver with THX Select 2
(I Use THX Cinema to achieve theater sound)
Speakers: Klipsch Synergy 5.1 setup ( Upgrading to 7.1)
DVD Player: Toshiba HDMI Progressive/HD Upgrade
[b]Cables[/b]
THX Certified 1000 Fiber Optic
THX Certified HDMI Cable
THX Certified Speaker Cable
THX Certified Acoustic Enhancing Cows : )
Relevant Product Info
You should check to see how hot that amp gets after listening to music/movies for a few hours, it looks like there isnt enough ventilation space there, other than that nice setup!
(I'd recomend looking for a receiver-fan on ebay if there is nowhere else the receiver can go, they are cheap, quiet and most have pass through outlets.)
Username: Willieman
PR
Post Number: 45
Username: Westcott
League City, Texas
Post Number: 115
Nice display and equipment choices.
I would suggest a little research into proper speaker placement and see if you can improve the situation.
Have fun and enjoy!
Username: Apresler07
Canal Winchester, Ohio
i like those THX Certified Acoustic Enhancing Cows
Username: Movie_collector
Folsom, California
U.s
Post Number: 8
I'd place a small fan behind the amp and lower the speakers. Rock on!
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Home Theater > Bragging Area > KrazeyKow's Mad Theater [ « Previous ] [ Next » ]
