Thread: Rookie seeks advice... |
New member Username: Birdmanjones
Post Number: 1 Registered: Jan-06
| Posted on Monday, January 09, 2006 - 11:00 pm: |
I'm in the process of adding on a new family room (about 15 x 18 feet) and as a COMPLETE newbie, am looking for any/all advice you might have. I'd like to set up speakers/wiring and a system while the walls are open. -I'll need a receiver and speakers (ceiling mounted?) and also would like to tie in all weather outdoor speakers for the small backyard patio area(about 20 wide by 15 deep) -I can only swing about $1,000.00 for the project. Won't be getting the big-screen, yet. I'd appreciate any direction as I'm starting from scratch. Thanks! |
Silver Member Username: Chitown
Post Number: 655 Registered: Apr-05
| Posted on Tuesday, January 10, 2006 - 01:10 pm: |
Look for a Marantz/Denon receiver refurbished for around $400 and then get a package speaker from Aperion or Axiom like this one: http://www.aperionaudio.com/system-builder/system-builder-preconfig.aspx Little more than a grand, but well worth it.
Post Number: 2 Registered: Jan-06
| Posted on Sunday, January 22, 2006 - 02:19 pm: |
Thanks Stof. Any recommendations on wiring? |
