Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through January 29, 2006 > Speaker wire problems
Author Thread: Speaker wire problems
Username: Chomperoni
Post Number: 9
My electrician ran speaker wires for my home theatre using 10 guage two wire.
I have hooked up my speakers succesfully using the wire and it sounds good, however, my sub needs a plug in type to connect. Can I hook up my sub using these wires if I put a plug on them or did he run the wrong wire for the sub?
Username: Westcott
League City, Texas
Post Number: 59
Ideally you will need a 75ohm cable with RCA connections on either side.
www.bluejeancables.com
Good quality and no snake oil. If nothing else, read what they have to say what makes a good low frequency transmition cable without hummm.
I have a Polk RM6000Black. Serial # RM6000BD07982L.
I need the wiring instructions to setup the sub-woofer. Can you provide wiring directions which would include connection to my WOW Cable service.
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through January 29, 2006 > Speaker wire problems [ « Previous ] [ Next » ]
