Home > Message Board > Home Theater > Home Theater in a Box > Archive through April 22, 2006 > Problem with FM radio in Neo6/Pro log...
Author Thread: Problem with FM radio in Neo6/Pro logic II on Onkyo HT S780
Username: Shankygup
I recently bought an Onkyo HT S780 after going through numerous positive reviews on the web.
I set it up and it does sound wonderful.
However, I have an issue when playing fm radio or certain mp3 files in neo6 or prologic IIx modes - only the front speakers and center speaker produce sound - the surrounds dont.
When I play an audio CD from the same DVD player which I used for the mp3s - in neo6 or plIIx, all speakers work fine.
Is this a problem with the receiver? Or is this expected?
Also, the built in modes - orchestra, unplugged etc only give me 5.1 surround (on same audio cd - which gave 7.1 in neo6) whereas the manual states that it should be 7.1
I am very confused. Have tried all the settings etc and double checked the wiring - that all seems to be fine.
Also since all the speakers are working fine in other modes or on different media - it does not look like problem in setup.
Any help is highly appreciated. I am out of my depth here.
thanks,
Shashank
Home > Message Board > Home Theater > Home Theater in a Box > Archive through April 22, 2006 > Problem with FM radio in Neo6/Pro log... [ « Previous ] [ Next » ]
