Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through January 29, 2006 > Plz Help me with sony dvd home theat...
Author Thread: Plz Help me with sony dvd home theatre system...
Robert Filiano
I just bought a Sony DVD Home Theatre System Model: DAV-DX150 for my dad for christmas. i set it up and it works GREAT on dvds, but when i try to use the system for sound when watching tv i only have sound from the one LEFT FRONT Speaker... I dont kno wats up but my dad really only watches tv so hes not enjoying it :-(
Check your connections as it sounds like you are possible using RCA's and one is loose. If you have a cable/satellite box with digital coax or optical outputs you may wish to use these over RCA's. Hope that helped.
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through January 29, 2006 > Plz Help me with sony dvd home theat... [ « Previous ] [ Next » ]
