Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through December 15, 2005 > Need advice for new system
Author Thread: Need advice for new system
I'm gonna buy a surrond sound home theater system and need some advice. For my bedroom which is about 12feet by 13feet, whats a good watts to get. I'm looking at one thats 300w and one thats 600w. Is 300w good enough for my room size? This is what im looking at, thanks!
http://www.circuitcity.com/ssm/Zenith-Home-Theater-System-ZHX-313-/sem/rpsm/oid/ 119869/catOid/-12954/rpem/ccd/productDetail.do
Username: Chitown
Post Number: 549
That unit will do fine in a small bedroom, but don't fool yourself. You will never get 300 watt out of that HTIB.
Evan3479
http://www.circuitcity.com/ssm/Sony-Home-Theater-System-HT-DDW670-/sem/rpsm/oid/ 119802/catOid/-13325/rpem/ccd/productDetail.do
How does this one look, im probably going to get this one!
Username: Chitown
Post Number: 551
Same. Don't look at the wattage. They are overblown numbers coming from these two vendors. Either one of these two should be plenty for your bedroom. Go and listen to them and see which you like best and can afford. You are not getting a high end system, so don't worry about the wattage.
Evan3479
Thanks, though circuit city doesnt have them out to listen to. I'll probably try brandsmar or bestbuy, thanks again!
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through December 15, 2005 > Need advice for new system [ « Previous ] [ Next » ]
