Thread: Ghosting? |
New member Username: Bswan98588
Milwaukee,
Wi
Post Number: 1 Registered: Dec-05
| Posted on Sunday, December 11, 2005 - 09:54 pm: |
Someone help! I recently purchased a 47" projection, Samsung hdtv. When hooked up to the HD box from my cable company, the picture is perfect. However when I go to watch a DVD, I get "ghosting" images going from right to left. I changed out the cables on it, but it didn't seem to make a difference. Can someone tell me what's wrong? I would guess if it were something wrong with the set I'd get the same ghosting while watching tv. HELP!!! |
Silver Member Username: Chitown
Post Number: 526 Registered: Apr-05
| Posted on Sunday, December 11, 2005 - 10:46 pm: |
It is the ghosts of the analog TV's past!!
Post Number: 527 Registered: Apr-05
| Posted on Sunday, December 11, 2005 - 10:48 pm: |
If you connected your DVD via a digital connection, check the setup of your DVD to make sure it is set to digital streaming. Also check the progressive scan.
New member Username: Bill_paul
La Mesa,
CA
Post Number: 4 Registered: Sep-05
| Posted on Tuesday, December 13, 2005 - 03:35 am: |
Blake, You need to give more information on how you have things hooked up. Otherwise we are guessing. Component video? S-video Through a receiver? Are you swapping cables or using multiple inputs on your Samsung? |
