Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through December 15, 2005 > Smart people help me please!!! Leads?
Author Thread: Smart people help me please!!! Leads?
Username: Sizey
Liverpool, England
England
i am stuck and very confused, i bought a televison and a xbox 360 and a 7.1 surround sound.
i was wondering if you could tell me if they are compatible. im sure you know the 360, my tv is on the link below
http://www.argos.co.uk/static/Product/partNumber/5290176/Trail/C%24cip%3D28956.S ound%2Band%2Bvision%3EC%24cip%3D29029.Televisions%3EC%24cip%3D29030.LCD%2Bflat%2 Bpanel%2Btelevisions.htm
and my surround sound is below
http://www.amazon.co.uk/exec/obidos/tg/stores/detail/-/electronics/B0006BAVEI/sy stem-requirements/ref=ed_tec_dp_2_1/026-6388993-3916442
please help me. wot leads do i need
Username: Chitown
Post Number: 533
You need an amplifier
Username: Sizey
Liverpool, England
England
wer do i get a amplifier from? can you give me a link dat is compatible for my systems stof?
Username: Chitown
Post Number: 536
Your problem is you bought your xbox thinking it will produce sound through the speakers. Yes it does produce sounds, much like a DVD player, but you can't hook up a DVD to speakers directly. You need amplification through a receiver or amplifier.
Now your other problem is that the speakers your bought are PC speakers for multimedia. They can only work (as far as I know) with a PC sound card. I don't know of regular receivers that drive PC speakers so you have to look around.
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through December 15, 2005 > Smart people help me please!!! Leads? [ « Previous ] [ Next » ]
