Thread: Help with NAD T 753 |
New member Username: Kenstl
Usa
Post Number: 1 Registered: Dec-05
| Posted on Thursday, December 08, 2005 - 08:15 pm: |
I have a NAD T 753 hooked up to a plasma tv via compenant video. All works fine with normal setup. Issue is with trying to plug in a Karaoke machine, sound and video to the plug in's on the front of the receiver. the sound works through my speakers, but no video. Is there something I need to change on my set up of the NAD? I cannot find anything in the manual. I thought it would be plug and play. Thanks |
Silver Member Username: Chitown
Post Number: 521 Registered: Apr-05
| Posted on Friday, December 09, 2005 - 10:24 am: |
Check out what the source is for the front plugs. It may be Aux1 or Aux2. As you are connected you may want to switch your sources and see what works.
Usa
Post Number: 2 Registered: Dec-05
| Posted on Sunday, December 11, 2005 - 12:56 pm: |
The front switches are labed "Video 6". When I switch over to this, the sounds works, but no video appears. Could this be something with regards to the quality of the video on the karaoke cd will not go through compenent video? (similar to the system navigation screen not working through compenent video?)
