Thread: Someone please help indeed i am a idiot |
Unregistered guest |
| Posted on Thursday, December 08, 2005 - 02:46 pm: |
i have a 32" sharp model number 32c240 in my bedroom and i am purchasing a 800 watt samsung dvd home theater system. but what scares me is as i am looking at the specs for the television it says "variable audio output - No". does this mean that i cannot connect my surround sound to the television and/or cable. is there anyway around this? otherwise this would really piss me off i'd be much greatful for the help |
Bronze Member Username: Turbodog
Post Number: 64 Registered: Jul-05
| Posted on Thursday, December 08, 2005 - 02:52 pm: |
I looked at the manual here: ftp://extra.abtelectronics.com/PDF_Files/32c240_operation.pdf I saw no provision for an audio out connection from the TV to an external receiver or HTIB unit. If you have a separate cable box, you might be able to get audio from that to the surround unit. |
Post Number: 4434 Registered: Dec-03
| Posted on Friday, December 09, 2005 - 05:55 pm: |
"Variable audio output" means that the audio output to an external receiver or amplifier can be controlled by the TV's volume control, nothing more than that. However, your TV will not be capable of producing surround sound, you need a receiver that is capable of producing surround sound and a source that is coded or surround sound. You said that you are purchasing a Home Theater system. The surround sound will come from that and not the TV. Follow this link and learn more about surround sound before you get pissy about your TV http://www.hometheaterhifi.com/volume_1_1/v1n1snd.html |
