Thread: Yamaha YHT-360 W/Sony Floor Speakers Upgrade |
New member Username: Ihernandez81
Post Number: 1 Registered: Dec-05
| Posted on Thursday, December 08, 2005 - 01:00 pm: |
Looking for some advise from owners of YHT-360 by Yamaha and Sony SSMF550H Floor Speakers. I just bought the whole thing but haven't set it up yet. I have to wait until we move in to the house but after reading some of the reviews on Sony Speakers and Yamaha Speakers from Theater in A Box systems I'm a bit dissapointed in what I bought. I haven't heard it yet and I already want to return the whole thing! A lot of the reviews and tips from other writters suggest that Sony speakers are over priced and don't sound good at certain frequencies and Yamaha speakers are just horrible. I think the only good thing I bought is the Yamaha Reciever, I didn't find any complaints on those but didn't find anything good on them either. Does anyone have any suggestions or previous experiance with these? My System (Still in the Box) Yamaha YHT-360 with HTR-5835 Receiver and Speakers Best Buy: http://www.bestbuy.com/site/olspage....=1099395730499 Sony Front Speakers that will replace the front speakers from the YHT-360 I'm going to use the Yamaha front speakers as my surround speakers. SONY SSMF550H http://www.bestbuy.com/site/olspage....=1051806317065 DVD PLAYER YAMAHA DVS-5750 http://www.bestbuy.com/site/olspage....=1089890284340 I listen to music all genre, but I'll mostly watch Movies (DVD). I guess I'm looking for some feed back on what you experts think about this setup, I'll go home tonight and try it out but while I'm here at work I wanted to see if anyone had some idea as to what I should expect to hear from this setup. Also the TV is: Sony 50" LCD Rear-Projection http://www.bestbuy.com/site/olspage....=1089890509997 |
Post Number: 4437 Registered: Dec-03
| Posted on Friday, December 09, 2005 - 06:10 pm: |
The only thing that matters is what you like. Listen to your system first and if you like them, you are set. Then go and listen to other speakers that are available in your area and decide for yourself. What people say is moot when you have the ability to make a decision on your own. You perception will be different from everyone else. |
Post Number: 3 Registered: Dec-05
| Posted on Wednesday, December 14, 2005 - 09:45 am: |
Ok Question: Amp has 720Watts x 6 at 6 Ohms, if I put 8 Ohm speakers on it, will they sound louder or quiter or will the receiver just up the volts to bring the watts up to 120W through an 8 Ohm connection? |
