Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through December 15, 2005 > Box or Card?
Author Thread: Box or Card?
Just got a Samsung HLR5678W. Should I use an Adelphia HD DVR box or go with the cable card?
Pros / Cons ?
You've got the recording capabilies with the box as well as movies on demand, etc. But the card can provide better picture quality
Username: Cuylar
Burnsville, MN
Post Number: 154
you can hide a cable card easier than a box.
thats helpful
the cable man
cards dont work
Username: Rug_muncher
Hooterville, Bamma
Confederation
i really like a good box
wow, i bet you do
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through December 15, 2005 > Box or Card? [ « Previous ] [ Next » ]
