Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through December 15, 2005 > Component video not working
Author Thread: Component video not working
Username: Smkbong
Iam trting to hook up my dvd player to my tv using component video cables, however i cant get the picture to work right, ex. i will get a green picture or something like that. any help???
Username: Cuylar
Burnsville, MN
Post Number: 144
its the cable or the plug... i had that happen with my Sharp 32" CRT and i found out that the plugs on the TV were broken inside from yanking on the cable too hard.
Username: Catskill
Tampa, FL
USA!
i have read elsewhere that this is some type of fault but I have to agree I think almost certainly cable. I even had that happen on my VGA to projector... if you tap it you would get a reddish picture or greenish picture. fiddleing with the cabel fixed it.
Username: Chitown
Post Number: 515
Start by plugging in the cables one at a time and look at the pictuer. You should be able to indentify which cable has a short. You can then run another RCA cable between the two ports and make sure before you spend money on another set.
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through December 15, 2005 > Component video not working [ « Previous ] [ Next » ]
