Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through December 15, 2005 > I'm getting no picture!!
Author Thread: I'm getting no picture!!
Username: Scndchance321
HI IM REALLY FRUSTRATED. i have a samsung HT-DB600 surround sound system i am trying to hook up to my TV. I went out and bought the component video wires for the tv. I hooked everything up and the sound is coming out of the dvd but there is no picture. all the wires are in the right spots.. It's a new tv. What can i do with the settings of the tv maybe??
Username: Cuylar
Burnsville, MN
Post Number: 141
Cycle through the video inputs. If that doesn't work try to see if a composite cable will spark on some picture. If you get video with another cable you probably have a bad cable. What kind of TV are you using? If you double check that the blue is going to blue and green is going to green that will help too. I have made that mistake in the darkness behind my tv.
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through December 15, 2005 > I'm getting no picture!! [ « Previous ] [ Next » ]
