Thread: New DVD Player Old Amp - Audio hookup |
New member Username: Ojivar
Post Number: 1 Registered: Nov-05
| Posted on Saturday, November 19, 2005 - 07:56 am: |
Hey all This is probably a stupid question but as I can find no other info I thought I would give it a try here. I have a Sony STR-DE375 Amp which has 5.1 Analogue inputs but no digital coax/optical inputs. Its a perfectly good amp and has no problems. However my DVD player is starting to die on me, I've had it 5 years so its had a good run! Problem I have now is all the DVD players I find that I like ONLY have digital outputs for sound and no 5.1, so my question is: is there any way for me to convert the digital output from the player into 6 analgoue inputs for the amp? I really can't afford a new amp and as there is nothing wrong with the one I have I am loathed to anyway. I want a player that has multi-formats (divx, xvid, dvd-r, dvd+r etc etc..) and these all seem to require digital sound outputs. Many thanks. |
Post Number: 4291 Registered: Dec-03
| Posted on Sunday, November 20, 2005 - 08:07 pm: |
Check out this DVD player from Pioneer DV-588A-S. It has 5.1 analog outputs so you can still connect it to your Sony.
Silver Member Username: Reinhart
Post Number: 146 Registered: Nov-05
| Posted on Sunday, November 20, 2005 - 10:11 pm: |
Another option is to try and find a used outboard decoder. But, Berny's suggestion to buy a player with 5.1 analogue outputs is likely to be a cheaper alternative. - Reinhart |
