Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through December 15, 2005 > Sony 60" SXRD on the way. Help me out...
Author Thread: Sony 60" SXRD on the way. Help me out with ideas for Home Theater system.
Username: Jmy350z
Edison, New Jersey
I just purchased the Sony 60" SXDRD television for my new place.Now I am looking for a home theater system to go along with this.My place is a small 1 bedroom apartment.I just want something that will sound really good.Should I look at Home Theathers in a Box? Should I just build this myself? Are there any HTIB's to stay away from? Thanks for the info
Username: Paul98
Post Number: 84
it's usually better to build yourself unless your budget is very small. How much are you looking to spend?
Username: Jmy350z
Edison, New Jersey
I have about 3k to spend
Username: Chitown
Post Number: 466
For 3K you don't need to look into a Home theater in a box solution. Look around this site and read the reviews and you ought to be able to find some great deals to make a good system
Username: Serlv
Las Vegas, NV
So, John Y., what did you go with? I too, just purchased a 60" SXRD to go in my living room; it was delivered on Saturday. The friggin' thing is huge. Once in there, I realize I could of easily have gone with a 50" and been ok. I hope that 60 works for you in a small apartment. My living room is 22'x16' and the Sony still dominates the room ( though not too much so :-) ).
What speakers did you go with? Need suggestions or are you already settled in with some?
Scott
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through December 15, 2005 > Sony 60" SXRD on the way. Help me out... [ « Previous ] [ Next » ]
