Thread: S-Video Overides Composite |
Blue_mikey Unregistered guest |
| Posted on Wednesday, October 26, 2005 - 03:53 am: |
OK, all my components are using s-video except my vcr. my tv's s-video when plugged into the jack overides my composite video jack. What can I do to get a vcr picture without unplugging my s-video jack everytime? |
Gold Member Username: Jan_b_vigne
Dallas,
TX
Post Number: 6332 Registered: May-04
| Posted on Wednesday, October 26, 2005 - 10:19 am: |
With the amount of information provided, the best answer you're likely to get is; get into the menu and hit the right switch. |
Bronze Member Username: Diverhank
Huntington Beach, CA
Post Number: 82 Registered: Sep-05
| Posted on Friday, October 28, 2005 - 08:33 pm: |
You are not being very clear but if I have to take a guess, you need to plug the VCR composite into a different TV input. Usually most TV have more than one input. For the same input, you can only use one and S-video is preferred so it will take precedence. If you don't have enough TV inputs for all your components, go to Walmart or RadioShack for a selector device. |
