Thread: Sony Dream system. |
vash336 Unregistered guest |
| Posted on Friday, October 21, 2005 - 05:11 pm: |
Well i just bought a sony dream system DAV-FR1 and it didnt come with a remote so i bought the kameleon universal remote to use it with. And i found the code to use the system and most of the buttons work (volume,chapter skip,fast forward,etc) but a few buttons dont work like Play,Stop,Pause or OK if you are in the menu screen on the remote. So I was wondering if anyone knows how to fix this or what codes do I have to type in to get them to work. Any help would be apprieicated thanks. |
Post Number: 4173 Registered: Dec-03
| Posted on Wednesday, October 26, 2005 - 12:43 am: |
Have you tried looking for the website that manufactures the Kameleon remote? Try going here http://www.ofausa.com/list_remotes.php?type=Kameleon |
| Posted on Wednesday, October 26, 2005 - 05:46 pm: |
i have that remote, it sucks, it uses batteries like there going out of style |
| Posted on Tuesday, November 01, 2005 - 01:50 am: |
i think you are kinda retarted and your remote must had a short because mine still has the display batteries and no problems at all |
| Posted on Thursday, November 17, 2005 - 06:33 pm: |
re(tart)ed is that a desert you moron |
