Home > Message Board > Home Theater > Home Theater in a Box > Archive through November 29, 2005 > Which is the best Onyko Home theatre ...
Author Thread: Which is the best Onyko Home theatre in a box?
Dan from Austin
I am looking at the 780, 770 and 570. The only thing that scares me about Onyko is that a lot of people have problems with there systems. They get very high reviews.
If you are choosing between these three and you have no budget, it would be crazy not to buy the 780. Circuit City is having 5 hour sales (between 11 AM and 4 PM) THIS week so I bet you could pick up the 780 for around $425. Last time they had a 5 hour sale they had the 770 for $399 but for only that week. The 780 is 7.1 over the 770 that was 6.1. The 780 also has Component switching for HDTV over the 570 and 580 and 670 and 680. Bottom line: Get the 780 if those are your only choices.
dan from austin
Thank you very much. Well I have a hdtv so that might be the way to go. I dont know Polk audio is kinda of looking better.
Home > Message Board > Home Theater > Home Theater in a Box > Archive through November 29, 2005 > Which is the best Onyko Home theatre ... [ « Previous ] [ Next » ]
