Thread: Xbox 360 |
New member Username: Shane_meister
London
Post Number: 5 Registered: Oct-05
| Posted on Sunday, October 16, 2005 - 06:38 pm: |
Will it be possible to hook it up to my 5.1 surround sound system even though i dont have a optical input outlet on it? The cables that my surround sound system uses are the ones that are red and white one one side and have jacks on the other similar to the ones you would find on your headphones... |
Bronze Member Username: Diverhank
Huntington Beach, CA
Post Number: 63 Registered: Sep-05
| Posted on Sunday, October 16, 2005 - 07:44 pm: |
You can only get simulated surround sound, not true 5.1 |
London
Post Number: 6 Registered: Oct-05
| Posted on Sunday, October 16, 2005 - 08:05 pm: |
simulated... as in??? not as loud/realistic... I have it hooked up to my dvd player and it sounds pretty good to me.. will it be the same on 360 with the audio cabels as on my dvd player cuz I am pretty happy with it also am i going to have to buy some sort of special cords like an extension so its compatable with my systems microphone jacks? (This is the most frustrating part for me) |
Post Number: 64 Registered: Sep-05
| Posted on Sunday, October 16, 2005 - 09:00 pm: |
I didn't say it sounds bad. It simply means that via the red/white RCA pair, you have a stereo (2 channel source) signal, not 5.1 discrete digital input (via optical or digital coax). The receiver will decode this stereo source and outputs it in 5.1 (hence "simulated"). It's usually pretty good but not as good as the true 5.1. |
London Ont Canada
Post Number: 7 Registered: Oct-05
| Posted on Sunday, October 16, 2005 - 10:14 pm: |
my reciever has input for the headphone like jacks though not the standard sized audio jacks. is their some sort of extension cable for this situation seeing as you cant just plug standard audio cables into my reciever... |
London Ont Canada
Post Number: 8 Registered: Oct-05
| Posted on Sunday, October 16, 2005 - 10:19 pm: |
like i said before they are red and white on one side and head phone jack on other and my situation is i need to be able to hook it up with an xbox 30 when it comes out... thx |
Reinhart Unregistered guest |
| Posted on Monday, October 17, 2005 - 12:09 am: |
To help clarify your question. What equipment do you have? - Reinhart |
digiguru Unregistered guest |
| Posted on Monday, January 02, 2006 - 09:07 am: |
I found this and thought it might help, it offers an optical attachment for your xbox 360 and a load of extra attachments like s-video and composite video. Joytech XBox 360 Digital AV Component Cable at Play.com I have no idea why micrsoft havn't made their own optical cabel, which causes me to be a little suspicious of it. If someone purchases it, let me know! |
New member Username: Sturge_01
Ponte Vedra Beach,
Florida
Post Number: 10 Registered: Nov-05
| Posted on Friday, January 20, 2006 - 11:39 pm: |
Hey, have a look at http://www.salehooo.com if you are looking for some top wholesalers for these! Its worth a look if your serious about getting some in! |
Post Number: 6047 Registered: Dec-03
| Posted on Sunday, February 19, 2006 - 05:12 am: |
