Thread: Can someone tell me wtf is goin on |
New member Username: Shane_meister
London
Post Number: 2 Registered: Oct-05
| Posted on Friday, October 14, 2005 - 10:06 pm: |
I bought a 5.1 surround sound system off the net and it just arrived today. When i hooked it up to my dvd/vhs system it worked except only 2 out if 3 of the channels work (center,front, rear) so basically if front and rear were workin, center was not and so on I checked all the speakers and it isnt them, I think its probably my connection. Im using standard audio cables that came with the package. Could someone please tell me what i may be doing wrong. this package has |
London
Post Number: 4 Registered: Oct-05
| Posted on Friday, October 14, 2005 - 10:11 pm: |
Do i have to set my dvd player to dolby digital or something... someone plz reply soon |
johndeereman Unregistered guest |
| Posted on Saturday, October 15, 2005 - 04:43 am: |
yes you need to go to your menu and activate your optical or coaxal digital out you cannot get dobly digital or dts from rca left and right cable. |
