Thread: Choice of Subwoofer |
Sub-Zero Unregistered guest |
| Posted on Thursday, April 15, 2004 - 04:06 am: |
I would like to seek help on which subwoofer to buy. I have 2 in mind i.e B&W ASW675 and JBL Northridge E250P. B&W ASW675 is a 5 star sub and it is 10" with 500 watts. The JBL E250P comes with a 12" and 250 watts. Can you guys out there please help me. I am using Yamaha RXV2400, B&W 603S3 (Main), B&W LCR60 (Centre) and Quad 11L (rear). Many thanks. |
pyle reseller Unregistered guest |
| Posted on Monday, June 07, 2004 - 06:47 pm: |
In my humble knowledge it goes like the bigger the better .... (in SUBwoofer mater) had a 15" pyle and never found that bone crushing feeling in any other subwoofer, just listen 2 it or feel it !?
Bronze Member Username: Feot
Texas
Post Number: 27 Registered: Apr-04
| Posted on Tuesday, June 08, 2004 - 04:28 am: |
Oh yes, bigger is better...what a pyle of crap. You have a home theater environment I assume by looking at your setup, so "crushing bones" isn't exactly what you're aiming to do, righ? With the two you've listed, the B&W would be a far better choice for your setup. The JBL may be too overpowering (or may crush some of your bones). |
Silver Member Username: Project6
Post Number: 640 Registered: Dec-03
| Posted on Tuesday, June 08, 2004 - 02:48 pm: |
have you listened to both of them? It is all a matter of personal preference at this point. a 10" sub will sound much different from a 12" even from the same brand. One not necessarily better than the other. There is always a compromise, i.e. a 10" would sound tighter and respond to rapid changes in the sound signal, a 12" would sound louder and fuller but is prone to slower responses on rapid low frequency signals, due to its inherently larger cone mass (it just can't go back and forth fast enough). listen to them both and pick out what sound you like. cheers |
