Home > Message Board > Home Theater > Surround Sound > Archive through December 14, 2005 > No Audio Out from TV
Author Thread: No Audio Out from TV
Username: Fishnejt
I have a new pioneer surround system that I got for a gift. I have the DVD player working throught the system, but I am stuck on the TV.
The TV only has 3 plugs one coax, one video in, one audio in. Since there is NO AUDIO OUT is there a way to run the TV through the surround sound?
Thanks in advance for the help.
-J
Username: Turbodog
Post Number: 12
No, but you can accomplish the same thing by buying a HiFi VCR (they go for well under $100 nowadays). Route the cable or antenna into the VCR, and use the audio output from the VCR. You use the VCR tuner to change channels, and your TV stays on channel 3 (or 4). I am assuming you use the video input on your TV for the DVD player.
HTH
Username: Fishnejt
Forgive my lack of knowledge of sound systems.
Can this be done with an RF modulator that has audio out jacks? And then feed the audio out jacks to the receiver on the surround sound?
Username: Diverhank
Huntington Beach, CA
Post Number: 49
Where would you connect the RF modulator to? I think your most practical solution is doing what Rick Nolan recommends. Get a VCR with a tuner. Either that or get a newer TV :-).
Username: Turbodog
Post Number: 16
I am obviously not familiar with every modulator on the market. However, every one I've seen has audio/video INPUTS and an RF OUTPUT. Typically these are used to connect newer components (DVD especially) to an older TV with only a antenna/cable input. So, without knowing more about your modulator, I'd have to say: no, won't work. BUT I could very well be wrong.....
Home > Message Board > Home Theater > Surround Sound > Archive through December 14, 2005 > No Audio Out from TV [ « Previous ] [ Next » ]
