Home > Message Board > Home Theater > Home Theater in a Box > Archive through April 22, 2006 > Panasonic problem...
Author Thread: Panasonic problem...
Username: Trumayhem
I recently bought a panasonis sa-ht733 home theater and have been in the process of setting it up. However when it is in tv mode the sound will randomly cut off. Now turning it off and then turning it back on it comes back on. Also switching to dvd then back to tv it comes back on. So is there any way to fix this or do I have a problem that I can't fix?
Username: Trumayhem
Just to be clear it is the tv option input which I currently have my xbox plugged into. like i said the sound works for a little bit and then just cuts off...
Username: Jlobao
I've been having the same problem with my Panasonic SCHT 15. If I switch a cable channel, the sound disappears from the receiver. When this happens I have to use the TV speakers. What the He ll? Anyone have any ideas...manual doesn't say?
Home > Message Board > Home Theater > Home Theater in a Box > Archive through April 22, 2006 > Panasonic problem... [ « Previous ] [ Next » ]
