Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through October 02, 2005 > Panasonic SA- HE70 back fan Questions
Author Thread: Panasonic SA- HE70 back fan Questions
Username: Hwoarang5
Hi i just got this amp and it works great, but i want to ask is it normal tat the back fan doesnt spin? will it only spins when its reaches at cetain tempeature? i used it for 2 hour plus yet to see the fan to run, is this normal?or my unit got problem?
anyone have this amp? can share any lights on this? thanks
Username: Arland_rae
Alberta
I have had the SA-HE 100 receiver for 2 years. It also has a cooling fan. As far as I can tell the fan has never turned on. I think if the receiver is well vented it will keep cool enough with out the fan. I don't think there is any problem with the receiver.
Username: Hwoarang5
i see, thanks for clearing it up, i was worried, hahaha...its is a great amp by the way....i love it~
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through October 02, 2005 > Panasonic SA- HE70 back fan Questions [ « Previous ] [ Next » ]
