Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through October 02, 2005 > Screen Size
Author Thread: Screen Size
Bil K
I am setting up a home theatre and need to figure out the optimal size and placement of my permanent screen. The room is 12' x 23" with theatre seating row 1 is 14' from the screen and row 2 is elevated 7" and is 22' from the screen
Username: John_s
Columbus, Ohio
US
Post Number: 454
A generally accepted rule of thumb is the viewing distance should not be less than twice the screen diagonal. Thus an 84" (16x9) screen wouldn't be too big for those in the 14' front row and still be impressive for those in the back.
Username: Paul_ohstbucks
Post Number: 2564
I recommend buying a 7' screen instead.
HEH
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through October 02, 2005 > Screen Size [ « Previous ] [ Next » ]
