Thread: Home theatre audio system for under $1,000 |
ramjet59 Unregistered guest |
| Posted on Friday, September 23, 2005 - 04:59 pm: |
I need suggestions on a home theatre system-- receiver,2 fronts, center, sub-woofer, and 2 rear, for under $1,000. I know it's not much, but I am on a budget. |
Gold Member Username: Paul_ohstbucks
Post Number: 2571 Registered: Jan-05
| Posted on Wednesday, September 28, 2005 - 12:26 am: |
That would depend on how you intend to use your system, and what qualities and features are important to you. Based on the above info, it would be a little difficult to make a recommendation. |
