Home > Message Board > Home Theater > Surround Sound > Archive through December 14, 2005 > HD sound format?
Author Thread: HD sound format?
Username: Freestylin59
Post Number: 7
Do HD shows on ABC, CBS, NBC, etc broadcast in dolby digital or is it just regular stereo?
Username: Paul_ohstbucks
Post Number: 2533
They broadcast in 5.1.
Post Number: 8
I'm getting my HD channels through comcast basic. If I just hood up my tv to m receiver through optical connection, will I be able to get 5.1 sound or do i need a cable box?
Post Number: 2541
No cable box is necessary, providing your TV can relay the 5.1 signal to the Tv.
paulsafool
..and what is the nonsense paul just spouted?
Username: Dmwiley
Post Number: 1151
Paul's advice is perfectly understandable. If the tv will pass a 5.1 signal after it receives it, the receiver should play the transfer as 5.1. What's so hard to understand about that or do you have a not so hidden agenda of Paul-bashing? Whose the real fool? No need to respond. The answer is readily apparent.
The MOFO has spoken.
Home > Message Board > Home Theater > Surround Sound > Archive through December 14, 2005 > HD sound format? [ « Previous ] [ Next » ]
