Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through October 02, 2005 > Best Value and Performance 5.1 Receiv...
Author Thread: Best Value and Performance 5.1 Receiver to power Orbs?
PianoProdigy
I'd like to get your recommendation. I don't want to sacrifice quality at the expense of a few bucks, but I really don't know where to start.
I'm planning on getting the Mod1 Orb system and possibly upgrade the center channel to Mod2.
Also, if you'd also recommend where to buy your recommended receiver.
Thanks!
Username: Paul_ohstbucks
Post Number: 2513
With your speaker setup, just about any entry level receiver will do just fine. Whether you pick HK, Pioneer, Yammi, or Denon doesnt really matter. Whatever you do, stay away from NAD because their HT receivers are awful and troublesome.
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through October 02, 2005 > Best Value and Performance 5.1 Receiv... [ « Previous ] [ Next » ]
