Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through May 25, 2004 > Digital coaxial cable -vs- standard v...
Author Thread: Digital coaxial cable -vs- standard video cable
Username: Kingdufus
Beantown
When hooking up a DVD player to a home theater receiver using the coaxial plugs, does the kind and quality of cable used really make a difference? Most of the time manufacturers recommend a digital coaxial cable which costs considerably more than video cable.
I have a very cheap 5.1 receiver hooked up to a dvd player with a video cable (supplied with the dvd player) via the coaxial plugs. Occasionally, the sound volume level changes (starts off low, then switches and gets very loud). I'm wondering if it is a problem with the cheapo receiver, or if the lesser quality cable could cause this to happen. THANKS for any feedback!
Receiver: Kawasaki AV1000
DVD player: Toshiba SD-V392
Username: Project6
Post Number: 440
expensive cables or for that matter, cheap cables, will not make a difference on a low end system.
A normal video cable will work fine for digital audio, low-fi and hi-fi alike.
By your description of the trouble you are having, it does not sound like a cable issue, but your recevier as you suspected.
Username: Kingdufus
Beantown
Thanks for the responses. I have sent the unit back for repairs. Thankfully, it's still within the warranty period...
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through May 25, 2004 > Digital coaxial cable -vs- standard v... [ « Previous ] [ Next » ]
