Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through October 02, 2005 > Plasma Monitor + AV Receiver
Author Thread: Plasma Monitor + AV Receiver
Username: Rotterdamsam
I don't understand why people buy plasma TVs. I'm looking at the Pioneer PDP-506XDE (with external tuner) but the tuner is crap and adds $1000 to the price of the screen. I'd much rather just get a commercial plasma monitor and use the tuner on my VCR.
Then I can buy an AV receiver to power my speakers. Here's my question: I live in Europe with no hope of HD broadcasts and where digital TV quality is so bad I'm sticking with analog for now.
1) Are there AV receivers with tuners (or better yet dual tuners) or should I just use my VCR for analog TV tuning?
2) Can anyone validate my theory on just buying a plamsa monitor (no integrated or external tuner)? Are there any other things I should consider when doing this?
Thanks!
Username: Paul_ohstbucks
Post Number: 2407
There isnt any need for TVs to have a built in tuner. You'll be fine using either the tuner in your cable/sat box. I doubt the VCR tuner would have very good resolution.
Thanks for the input Paul. I only have analog cable because I live in europe and the digital cable is crap right now. I decided on the pioneer PDP-506XDE which just came out. It has an external tuner with a proprietary "system cable" to the TV. The next question is what is the best way to hook up my other devices (xbox and vcr)? Through the pioneer-provided tuner and then to the A/V receiver for surround sound or everything into the A/V receiver and have the A/V receiver output to the pioneer tuner?
Thanks!
Username: Chitown
Post Number: 318
Yes Sam. Make the TV a dumb terminal. This would be the easiest way to go and certainly produces better sounds.
The idea of a commercial monitor is interesting. What is the kind of monitors have you looked at and what prices? Are they actually cheaper?
Actually Stof I'm not sure the monitors alone are cheaper after you buy the connectors you'd need. I decided to go with a consumer model (PDP-506XDE) because it has an external tuner which I need for analog cable. Plus it has a handy PC input.
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through October 02, 2005 > Plasma Monitor + AV Receiver [ « Previous ] [ Next » ]
