Thread: DVI-I to HDMI or DVI-D to HDMI ? |
New member Username: Orc
Post Number: 1 Registered: Sep-05
| Posted on Wednesday, September 14, 2005 - 04:21 pm: |
Has anyone succeeded using an Ati Radeon with DVI-I output to a HDMI input of a LCD tv using DVI to HDMI adapter? I have read that connecting a video card like Ati Radeon 9700 pciex , to a LCD tv through HDMI using DVI to HDMI adapter, will produce NO IMAGE, because the DVI output of the Ati is DVI-I , and the HDMI input can be combined only with DVI-D output…Is this true?
Relevant Product Info
Post Number: 2 Registered: Sep-05
| Posted on Friday, September 16, 2005 - 05:24 am: |
So...no one knows?
| Posted on Saturday, December 10, 2005 - 11:04 am: |
No,thata not true. U should be able to connect |
Lindsay Shaw Unregistered guest |
| Posted on Monday, January 02, 2006 - 06:25 pm: |
Yeah from what i have read in multiple locations, including here: http://www.hometheaterhifi.com/volume_11_4/feature-dvi-hdmi-hdcp-connections-11- 2004.html it should be fine. I will be trying it with my Nvidia 6600 dvi-i output to my soniq 27" LCD soon, and will let you know. It already works beautifully on the vga output. |
NICKMANX83 Unregistered guest |
| Posted on Wednesday, February 08, 2006 - 04:21 am: |
I connected my ATI X800 Pro 256 VIVO AGP 8x to a Toshiba 26" CRT HDTV widescreen through both DVI-I to HDMI using a DVI-D singlelink >-> HDMI cable and through 9pin S-out >-> Component video. I recieved video, no problem. I was a little worried about some of the flicker caused at 720p through the HDMI. I am still trying to resolve this issue. I think I may be getting some interference from some other equipment. Although 480p and 1080i worked great. Of course there are problems with a desktop running an interlaced refresh rate. If anyone has resolved any problems with 720p in the same manner I have described here please post to satisfy my curiosity. |
