Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through October 02, 2005 > Converting digital output to analogue...
Author Thread: Converting digital output to analogue 5.1 system.
hi,
i have a 5.1 surround system, where you plug the 6 lines into the back.
i was woundering if there is any way i can use this setup with my PS2, which has a digital output.
is there some magic box i can plug the ps2 into, which has my 6 leads coming out of it to plug into to my 5.1??
thanks.
Username: Project6
Post Number: 3980
yes, it is usually called a surround sound receiver that can accept digital inputs. Doesn't your 5.1 surround system have inputs for digital?
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through October 02, 2005 > Converting digital output to analogue... [ « Previous ] [ Next » ]
